Re: New Pool
Ok, I got the K-2006 test kit today. After much frowning and testing I got the following results.
Chlorine 10ppm
pH needed 2 drops of R-0006 to be 7.4
Alk 90ppm
Calcium 220ppm
Cyanuric Acid <30 filled small test compartment and could still see black dot (barely)
Table D is 10.3oz (Sodium Carbonate) for 10,000 gal pool. I have about 13,500 gal pool. So I need a scale now??
