Results 1 to 10 of 11
Thread: 27,000 gallon green swamp HELP
    May 2012
    columbus ohio
    Unhappy 27,000 gallon green swamp HELP
    I just took the cover off my pool vaccumed it and the added 5 bags of shock,algaeside, clarifer& iron mite
    I did that @ 9pm last nite pool is still green WHAT CAN I DO!!!!!!!
    Default Re: 27,000 gallon green swamp HELP
    1. Add 7 gallons of PLAIN 6% bleach this evening. (about 15 ppm of chlorine -- use only 2 gallons if the algaecide had copper in it!)
    2. Read the test kit page in my signature; get a cheap OTO kit *or* a HTH 6-way, if the Walmart in your area has one.
    3. Test your pool, and tell us what you find, what the water looks like, what your pump / filter make/model are.
    4. Do NOT add any more pool store chemicals, tell you have test results.
    5. DO tell us EXACT brand & product name of what you've added.
    6. Tells EXACT names of any chemicals you have left.
    May 2012
    columbus ohio
    The pool pump is a Dynamo the sand filter is a intex and the shock granules were called shock xtra by utekem
    Last first: "were called" -- are the granules gone, or do you still have some?
    You have an Dynamo pump and an Intex sand filter on a 27,000 gallon pool? That doesn't sound right. What are the dimensions of your pool?
    Have you added bleach? Do you have an OTO kit? Did the pool hold chlorine overnight?
    May 2012
    columbus ohio
    The pool is 27' round the pump is a 1-1half pump ,150lbs capacity filter system.
    The pool water is still green. We have been vaccuming it out . Had a lot of leaves
    On the bottom. Dont have any more chemicals . So do I add more bleach now
    That I have it vaccumed out .
  1. Opened for first time with old loop loc mesh cover green swamp
    By Gretzky99 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-04-2013, 10:01 AM
  2. Came home from Afghanistan to a green swamp of a pool
    By NavyChief in forum Dealing with Algae & Slime
    Last Post: 03-31-2012, 07:01 PM
  3. Just pulled cover off.. green swamp water
    By slade8200 in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 07-18-2011, 06:59 PM
  4. Green Pool / Swamp complete with frogs...
    By JenLM in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 06-13-2011, 03:11 PM
  5. Ah, my 29K gallon hot tub.....
    By aylad in forum General Interest
    Last Post: 08-07-2010, 12:32 PM
