No CYA
Pool store guy says my CYA measured at 30 ppm. I just got my K2006 kit today and tested on my own, because I didn't believe him. What I got was not 30 ppm. I filled the tube to the top and could still see the dot at the bottom, although it was obviously cloudy. I don't want to keep retesting since there aren't many CYA tests in the smaller kit, but I can if you think that is my best bet right now.
If I don't retest, I plan to add CYA. Only problem is that we suspect there is a leak in our skim line, so often we only run off the main drain. How do I add the CYA if I can't add it to panty hose in the skimmer?
27,000 gallon, plaster, free form pool from the 70's. Hayward Pro Series High Rate Sand Filter, model 5244T. Jacuzzi Magnum Force Pump. PF:4.5
