Thread: In need of advice, once again!
    Jun 2011
    Northern VA
    Default Re: In need of advice, once again!
    aylad
    Thank you, you are correct the pool has not been high on the priority list but I don't want to come home to something that will take weeks to clear up.
    Here are the current numbers:
    fc 7
    cc .5
    ph 7.8
    ta 120
    cya - I have read some discussion on how this test should be done here so don't laugh.
    facing the sun 40
    back to the sun 50
    Thanks again for all your help, I don't own a cover, but #2 and #3 are possibles. The pucks and the floater I know I can get, not sure where to get the polyquat.
    Renee
    Last edited by rannrich; 05-22-2012 at 03:53 PM. Reason: to correct ta from 12 to 120 ppm
    27 ft x 52 in AGP
    Hayward Power flo LS 1.5 hp - Hayward model s180t sand filter
    27' round 17.2K gal AG pool; hand fed; Hayward model s180t sand filter sand filter; Hayward Power flo LS 1.5 hp pump; 24/7hrs; Taylor Complete FAS-DPD Pool Water Test Kit K-2006; orig. truck but use well to resupply; summer: ; winter: ; ; PF:7
    A CYA reading of 40 and 50 are basically the same since that test is pretty subjective anyways. Do you have a neighbor who could come by every few days and dump a couple gallons of bleach in for you while you are gone? That is also another option.
    (My sympathies to you.)
    Jun 2011
    Northern VA
    Thank you Watermom,
    Unfortunately, we have no one that will be able to help us out next week.
    27 ft x 52 in AGP
    Check your pool store for the Polyquat. Do NOT substitute a different one. Some others cause lots of problems. If you can't find it, don't worry about it. Use Janet's suggestions above and if you do have some algae when you get back, we can help you get it cleared up. There are lots of things in life more important than a pristine swimming pool. Deal with what is important now and we'll help you worry about the pool later. Take care.
