Re: Help determining what yellow is on pool liner
Unfortunately, the yellow does not brush away. I read through many posts in this forum before I joined, and originally thought that might be mustard algae. Since it did not brush away, I then thought it might be scaling and researched that. However, when I got in the pool to try and get a sample, it did not appear to have any roughness. It feels like vinyl. There is no difference in feel between the regular and discolored areas. The color is not a bright yellow, and is in the deep end and along the edges. I don't see anything in the center of the shallow end. We do keep it covered with a solar cover whenever it is not in use.
Any other suggestions are sincerely appreciated. Thanks! Pam
IG liner pool w/ diving board; 1HP pump w/ dual cartridge filter
