Results 1 to 10 of 13
Thread: Filling pool tomorrow
    BigDave's Avatar
    Default Re: Filling pool tomorrow
    What's in the granulated shock, cal-hypo or dichlor?
    xJustin is offline Commercial pool users, operators, owners xJustin 0
    Apr 2012
    Arkansas
    Calhypo. In previous years we've had to use 50 lbs a day just to maintain a steady level of chlorination. We have two chlorinators that use the round tabs, but I'm not sure if they work full strength. One seems to empty out the tabs daily while the other takes about a week(both turned on the max setting)
    BigDave's Avatar
    Can you dose the cal-hypo into the skimmers to have it dissolve on the sand in the filters? If you do, be darn sure the chlorinators are on the outlet of the filter and there are no other chemicals before the filter. Cal-hypo can mix with dichlor and triclor and CYA to go boom.
    Try swapping the inlet lines between the chlorinators and see if that moves the problem. If so, maybe it's the tap or a crushed line on the inlet side. If the problem doesn't move then maybe it's a similar problem on the outlet side.
    Apr 2012
    Arkansas
    I'll switch up on the chlorinators, and they are in fact on the return side.
    On the skimmer, everywhere I read says pouring shock into skimmers is a nono, is this not true?
    We took some water to the local pool supply shop for testing and they sent us home with $600 worth of Chems.
    100# calcium
    2 bottles of "phosfree" or something along that line
    200# sodium bicarbonate
    50# of stabilizer
    Does this seem plausible? Or did we get oversold
    Sorry Justin;
    We've been slammed with traffic, and I'm not keeping up.
    1. Think twice about using the Phos-free stuff. It will cloud your pool for days, and my guess is you are trying to open this weekend.
    2. If you have access to a Sams Club and can buy their PoolBrand dichlor 50lb buckets, I'd recommend buying (3) of those, and using dichlor to chlorinate AND add stabilizer. If you can do that, take the stabilizer back.
    3. If you also have access to cal hypo in 50 or 100lb buckets, I'd recommend using THOSE as a the primary source of chlorine (once you have used the dichlor). Cal hypo adds both chlorine AND calcium, so if you have access to cal hypo, take the calcium hardness back.
    4. If they are selling you the sodium bicarbonate at less than $0.50/lb keep it, otherwise you can get it cheaper at Sams.
    5. You need a K-2006C test kit PLUS an OTO kit for daily tests. If Walmarts in your area handle the HTH 6-way, I'd recommend buying (2) of those and (1) K-2006 for your testing.
    6. What is your daily swimmer load?
    7. Do you have health inspection on the pool?
    8. If you do NOT have health inspection, I'd recommend running very high CYA levels, which will allow you to dose chlorine 2x - 3x per week and STILL maintain good sanitation in between. One of the huge problems on commercial pools is maintaining adequate chlorination with varying loads AND varying staff. With high CYA *and* high chlorine, you can store large quantities of chlorine IN the pool water, which allows you to have the 1 or 2 competent people you may have do all the chemistry.
    Good luck!
    Apr 2012
    Arkansas
    Thank you for the reply!
    Yes we are being inspected tomorrow, and supposed to open Saturday morning. I however may be able to delay that 24-36 hours. Should I just take the phosfree back? I think they charged 42.00 a bottle for two small bottles.
    We do have a corporate account with Sam's, so I'm sure we can pick up the dichlor. I will just need some info to help persuade corporate that we need the dichlor since they already bought us 2 tons of calhypo. What are the benefits of initial shocking with dichlor opposed to calhypo? Would it be counterproductive to shock today with calhypo so we pass inspection tomorrow, then do a dichlor shocking?
    We get our calhypo in 100lb buckets, but it apparently is very cheap and doesn't dissolve well leaving a sludgy-sand type coating on the bottom of the floor. However, I already added one 50 pound bag of calcium hardness to the water, should i take the other bag back?
    actually was 1.19/lb lol... but I took it back as we found 6 bags of it we had in chemical storage.
    I'll see what we can do in obtaining those, but it may not be possible. Corporate shipped us two test kits that use tablets and drops, but I don't recall the branding. They were used, but seem to work ok. I'll find out what they are and post later.
    Varies fairly dramatically, anywhere from 30-60 on a weekday, to upward of 100-150 on the weekends.
    Yes, monthly with the first being tomorrow. She wants the pool clear, presentable, and uses test strips to check ph and chlorine.
    I got a test ran on our fill water from our pool supplier, I'll post the numbers here.
    Free Chlorine - 0.7ppm
    Total Chlorine - 1.8ppm
    Combined Chlorine - 1.1ppm
    pH - 6.9
    Hardness - 184ppm
    Alkalinity - 31ppm
    Cyanuric Acid - 0ppm
    Copper - 0ppm
    Iron - 0ppm
    Phosphate - 300ppb
  1. Filling pool with firehose???
    By SeanB. in forum In-Ground Pool Construction and Repair
    Last Post: 10-05-2006, 10:58 PM
  2. Need help for pump install Tomorrow PIC!
    By lmnharris in forum Pool Equipment & Operations
    Last Post: 08-12-2006, 04:23 PM
  3. cloudy water Desperate party tomorrow!!
    By timmie in forum Dealing with Algae & Slime
    Last Post: 08-11-2006, 12:10 PM
  4. Filling the pool after plastering
    By JonnyG in forum In-Ground Pool Construction and Repair
    Last Post: 05-25-2006, 02:11 PM
