Thread: Best pump/filter combo for 21' above-ground pool
    May 2012
    Michigan
    Question Best pump/filter combo for 21' above-ground pool
    Having a heck of a time getting accurate information about replacing our present pool filter system, which is a Hayward ASL series. They're not around any more, and I don't think I'd want one anyway, but what do I want? Conflicting information about the correct size pump to get, whether to buy a filter system with pump or as separate components, which do the best job, use the least energy, last the longest, etc. Any suggestions? We have a 21' round pool, 15,000 gallons I believe.
    Default Re: Best pump/filter combo for 21' above-ground pool
    Hi andiques,
    We have a few very knowledgeable folks on this forum in regard to pump/filter matching, and I'm sure that one or more of them will be by shortly to give you some good information....you're doing yourself a favor by researching this now, rather than after you get a mismatched pump/filter and then have to figure out how to deal with the problems it causes!
    May 2012
    Michigan
    wondering about the Hayward Xstream filter system (1 HP)... ?
    I don't know. Sorry for the slow responses to your question .... the forum's extremely busy right now but someone will be along who can address that question for you. Welcome to the Pool Forum, by the way!
    Hi Andiques;
    "Best" varies from person to person, and pool to pool. Having an oversized pump with an undersized filter is NEVER best, but otherwise, there's a lot of variation. To help you effectively, we need more info. I figured your gallons at ~9,500 (based on 21' diameter, 3.7' water depth), so the optimal MAXIMUM flow rate is about ~25 gpm, but there are other questions to answer.
    + Would you rather get AG gear or IG (inground) gear? IG gear will cost about 2x as much, but is likely to last 2x as long. However, if your AG pool is 10 years old, it may not make sense to spend $1,000 on a pump and filter that will last longer than your pool.
    + I'm guessing there are not restrictions on water use in Michigan, and that water is not terribly expensive . . . but I should ask, anyhow. Cartridge filters use less water.
    + Which is more important to you: ease of use or water clarity? DE filters give greater clarity, but sand filters are easier.
    + What characteristics of your existing filter system have you liked? Disliked?
  1. Need advice re: heater/pump/filter combo
    By ukdavo in forum Pool Equipment & Operations
    Last Post: 05-28-2013, 07:41 PM
  2. Intex combo sand filter SWCG question
    By rmk_racer in forum Intex-type Pool Setup & Operations
    Last Post: 06-15-2012, 11:05 PM
  3. Pump and filter combo.
    By JohnH in forum Pool Equipment & Operations
    Last Post: 07-09-2007, 03:43 PM
  4. suggest a good sand filter/pump model combo for 24' AG
    By ScottS in forum Above-Ground Pool Construction & Repair
    Last Post: 04-01-2007, 01:06 PM
  5. Anyone know where to buy Filter/pump combo with 2 speed pump?
    By poolbuoy in forum Above-Ground Pool Construction & Repair
    Last Post: 05-13-2006, 09:25 PM
