Results 1 to 10 of 20
Thread: Hello and CYA @ 240-300
    Default Re: Hello and CYA @ 240-300
    I've never really had a personal pool.
    My sons swam in a variety of institutional pools while they were competing, and we had access to others as a family. What we all prefer are 25 - 50 yard pools for SWIMMING, and ocean, lake or stream water for PLAYING. My wife would -- she thinks -- enjoy a pool to puddle in, sort of a summer time 'cool tub', but the rest of us get antsy if there's not something to DO, and she wouldn't enjoy it, if we were all trying to escape. We had an Intex one summer for testing, and none of us really liked it -- because we are all actual swimmers, anything less than 50' feels 'tiny'. My sons glide 15' - 20' from the push off, so in most pools they can only take 1 - 2 strokes before they have to turn.
    Also, prime pool time, I've always been working 70 - 90 hours per week, and dragging my family alone. Add in summer league swimming, with 2 meets and 4 practices per week, and USS long course (50m) swimming . . . we had ZERO time for personal swimming till fall.
    We've occasionally had access to some pretty exotic home pools, and have enjoyed those when we had the time.
    My commercial pool customers? I've run them every which way I could, trying different things to get the best results. Currently, my sole remaining local customer is at CYA = ~95ppm (the inspector will dock 2 pts for 100 ppm) and FC = 7 - 15 ppm (accepting the 2 pt penalty).
    May 2012
    NorCal
    I took some water to local pool store for testing. Somehow, they came out with CYA=70.
    Not sure what that means... I'm going to retest today.
    If it's really 70 then I should be able to test without diluting the water first.
    25k gal IG pool
    It means -- if it's accurate -- that you have enough CYA in your pool without adding more. One way to check is dose with chlorine in the evening, wait, test, and then retest in the AM. If the chlorine doesn't drop much, then you don't have any unusual chlorine demand. Wait again till the following evening, and test again: if it doesn't drop more than 1/3 - 1/2 during a sunny day . . . you have a fair bit of CYA in the pool.
    If it's any help, I am in Northwest Louisiana and my pool gets full sun from sunup to sundown and has a pretty heavy bather load from mid April through beginning of Sept--we also have a very warm, humid climate (today's high is 96 degrees, so far)....I keep my CYA at 80-90, and my chlorine in the 8-12 range. No ill effects on the kids, no faded suits or liners, no skin or eye irritation reported.
    May 2012
    NorCal
    My original testing (240-300ppm) and retest after partial drain (160ppm) was done by mixing 3 cups of tab water and 1 cup of pool water. I then multiplied 4 to the reading.
    I'm not sure how my testing of 160 is so far from pool store's 70 reading unless diluting water is messing up the reading or pool store's testing is way off.
    25k gal IG pool
    The tap water is not the problem -- there's no CYA used in potable water treatment. But, there are a variety of ways for CYA tests to be inaccurate -- it's by far the most subjective of the tests in the K2006, and is a good test ONLY in the sense of being better than 'guess-strips', and in being 'good enough', but only barely!
    May 2012
    NorCal
    I tested water with K2006 yesterday and it was clearly over 100.
    I guess this tells you can't really trust test results from the pool store.
    25k gal IG pool
    Quote Originally Posted by han78216 View Post
    That's why we push for people to learn to test their own water. Pool store test results are designed to sell chemicals..
