Results 11 to 13 of 13
Thread: Hole in pool filter
    May 2012
    canada
    Default Re: Hole in pool filter
    done thanks,
    I know someone selling a used jacuzzi filter, no valve or laterals just the tub. It is about the same size as my hayward filter. Provided that my hayward vavle and laterals fit in the jacuzzi tube, any issues in combining the two??
    Sounds like a project for an EXPERIENCED tinkerer. Or, in other words, if you have to ask me whether you can do it or not, the answer is, "Probably not!".
    People do succeed at projects like this, but it's generally people with very strong mechanical skills and knowledge, who do it more for the fun, then the savings. But we hear from other who try with less skill and less patience, and in those cases it usually hasn't gone so well. This year, it's been people buying used AG pools "for cheap", and then discovering that it's going to cost them hours and hours and a small fortune to put it into use.
    I am not sure, but I'm positive that the filter clamp/ band won't hold 2 differently branded pieces together.
    As Ben said, a competent 'tinkerer' might be able to work something out - but, I wouldn't try it!
    Please keep it safe while you solve your issue!
    If you want some suggestions on applying the epoxy putty, simply ask and I'll tell you what I know.
  1. Filter Housing has a Hole
    By fatlip in forum Pool Equipment & Operations
    Last Post: 04-19-2012, 12:05 AM
  2. need help! pool company dug hole and...
    By maggiemaye in forum Above-Ground Pool Construction & Repair
    Last Post: 06-27-2011, 12:39 AM
  3. Hole in Fiberglass Pool
    By Skillset in forum In-Ground Pool Construction and Repair
    Last Post: 08-08-2007, 11:58 PM
  4. hole in sand filter tank
    By jaymst in forum Pool Equipment & Operations
    Last Post: 07-08-2007, 11:27 PM
  5. Sink hole, pool not level...
    By posguy in forum Above-Ground Pool Construction & Repair
    Last Post: 06-11-2006, 11:18 PM
