Results 1 to 8 of 8
Thread: Testimonial to POP...numbers better everyday but still need help with cloudy water
    Default Re: Testimonial to POP...numbers better everyday but still need help with cloudy wate
    I think part of your problem is that you think this is an EXACT science. But, it's not. There are no magic chemical levels, where at pH 7.3421 exactly, the calcium starts to precipitate, or at FC=15.03ppm the algae will start to die.
    Pool chemistry is approximate, not exact! There are no 'perfect' levels; there's only 'good enough', or 'not good enough' . . . and where those levels are varies from pool to pool.
    So, for example, you need to think of your pool as "27,000 gallons" (or more likely, 26,000 -- values by liner companies and builders are almost always inflated!), NOT 26,696 gallons.
    Here's a general chemical rule that will help you avoid problems: "When treating your pool, if you are unsure, over-dose with chlorine but under-dose with everything else!"
    May 2010
    Central NJ
    Probie, don't sweat 7.6 so much as focusing on getting CC to 0 like you said. I run my pool at 7.8 because my source water and natural tendency is there and I would rather adapt to it's inclination than fight it if the fight isn't worth starting. bring up the Cl. You must have read it here somewhere, "shock" is a verb. So get to action. stop playing "touch and go" and kill the stuff living in your pool. Sometimes the best defense is a good offense.
    33,000ish gallon, 20X40 IG Vinyl Liner, no heater. Full sun, Sand filter. Been pool stored more times than I can count, not anymore! Thanks PF!
    20'x40' rectangle 33K gal IG pool; Bleach; Hayward sand filter; AO Smith 1HP pump; 14hrs; Taylor K2006; utility water; summer: ; winter: ; iPhone; PF:3.6
