Thread: FC remains 0/0, use bleach?
    Default Re: FC remains 0/0, use bleach?
    1. Tell us what the strips say. (They are not very accurate, but are better than nothing.)
    2. Start adding 2 gallons of PLAIN 6% bleach (or 2 1/2 96 oz bottles) each evening. Brush the pool completely to stir up any algae -- but make SURE you've added bleach before you do this.
    3. If the Walmart in your area carries the HTH 6-way test kit (not strips!) get one, and tell us what test results with it, are. You can check, here;
    http://www.walmart.com/ip/HTH-6-Way-Test-Kit/17043668
    4. List the EXACT chemical ingredients shown on the "Super Shock" and the "Algae Guard". If the tabs do NOT show copper as an ingredient, go ahead and put several in the skimmer or your floater. But, do NOT buy any more of those: we try to avoid voodoo blended chemicals like those products.
    5. Use your OTO / phenol red kit to check your pH. If it is HIGH, read the muriatic acid page, linked in my signature, buy a bottle and begin adding it 1/4 bottle at a time. Wait a day between doses. Continue till your pH reaches 7.6 If your pH is LOW, buy 4 boxes of 20 Mule Team Borax (exactly that, not something 'similar'), and begin adding a box at a time -- slowly, through the skimmer, pump running -- each evening. Continue till your pH reaches 7.2
    And ........... do yourself a favor and buy a good kit. The one we recommend is the Taylor K-2006 or 2006C. See the testkit link in PoolDoc's signature above. (You cannot buy this kit locally. You'll have to order it online. It will take a little while to get it, so still get the HTH 6-Way kit he suggested above.)
