Page 4 of 4 FirstFirst ... 2 3 4
Results 31 to 35 of 35
Thread: New Member, yucky pool
  1. #31
    May 2012
    Wisconsin
    Default Re: New Member, yucky pool
    I just checked the acid I bought. It's the 31%. So should I try to guesstimate about 1/8 gallon for our pool?
    15' round 4.9K gal AG vinyl pool; bleach; Hayward Perflex EC45 DE filter; Hayward 1HP pump; hrs; HTH 6 way,Will upgrade ASAP; well (very hard water); PF:25
  2. #32
    Yes, about 1/8 of a gallon which is about 2 cups. Don't measure it out, though. Just estimate. And, be upwind of the fumes. Nasty stuff.
  3. #33
    1. You're alkalinity causes the pH to rise over time. This page explains what's going on:
    http://www.poolsolutions.com/gd/lowe...p-by-step.html
    2. I'd recommend starting with a 1/8 - 1/4 gallon dose -- don't measure, guess. That may be too much, but with your TA as high as it is, it will just climb back up. (The good thing about muriatic is that it's really, really unpleasant long before it's really dangerous -- but still, if you don't try to pour and measure, you won't get a snoot-ful)
    3. Do continue with 1/4 bottle of bleach each evening. If your pool's FC gets too high, skip the next dose.
  4. #34
    May 2012
    Wisconsin
    Hello again. I must say that so far this has been the easiest pool year for us, ever. Thanks for all your help.
    I see there is now a sticky thread on the lime softening. That is what I came in here for. Our ph keeps creeping up and we are getting calcium scaling starting all over the walls. I will print out the directions. Looks rather complicated, so I will need to get more test chems before I do this.
    But other than the hardness problem, we have not had algae, even though we've had an intense heat wave and pounding sun for weeks on end. Thanks so much pool doc! We also have not had to keep changing the DE in the filter. Still using the original and not bumping all the time! It's wonderful!
  5. #35
    Glad you're able to enjoy your pool this summer and not spend all your time working on it!!
  1. New Member - Pool Newbie saying hello
    By rmergen in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-16-2013, 09:21 AM
  2. New Member with New pool
    By LarryW in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 08-29-2012, 01:28 PM
  3. New Member - planning new pool
    By GregC in forum In-Ground Pool Construction and Repair
    Last Post: 04-17-2012, 07:23 PM
  4. new member, new pool
    By dawgster in forum Pool Equipment & Operations
    Last Post: 02-08-2012, 06:04 PM
  5. New member and pool owner needs help.
    By mastamoon in forum Dealing with Algae & Slime
    Last Post: 09-16-2011, 05:44 PM
