This is nice to have somebody give me some direction in this.
Well we got it empty today except some bottom sludge. I started scrubbing. The stuff is coming off the bottom quite well. With a scrub brush and elbow grease and then I'm sucking up the sludge with a shop vac.
Having problems with the walls. I think we really screwed ourselves and put the liner in upside down. We have the smooth side to the inside, (the swimming side). And seem to be having more problems than ever. It looked like the right way as the seam edge is then to the outside. The entire walls have what I assume to be calcium deposits, but have never had this bad of problem before. Very rough, white. I've got some lime a way. But could I maybe uses like the thick toilet bowl cleaner?
I saw on another thread that you get a % of amazon sales through the links. I will definitely try to use that link for all my shopping on there. This site is wonderful and I'm so thankful to have someone to ask. Money is tight and I think we could save a lot this way.
For start up we do still have some Sock It left from last year. We could use that up first and then switch to bleach or not? Thanks so much for your help.
Hello again, So that I can order through Amazon and have it get here when ready to fill, could you give me an idea what I need to order? I'm going to town tomorrow to buy the small test kit for temporary and will order the better one. I'll also pick up bleach, and whatever else you say I need from WalMart.
So the manual that came with the pool says 5200 gals if dished. It is dug down quite a bit to about 5' at the center. We have well water, high calcium not too high of iron but some iron. We once had the pool turn bright green when we chlorinated. Pool store guy said it was copper. But that only happened one time. I don't understand either.
What should I buy for a stabilizer? I'm really dumb on stabilizers. But after reading more see that it's very important. I'm anxious to get filling but will be a while before it's all scrubbed. I have a messed up rotator cuff in my shoulder and can only scrub for so long. Also, just from your experience I would think we'd need to lower PH? I will test, but don't get to town every day so would like to have the stuff on hand if possible. Thanks again for helping.
Reason: combine sequential posts
