Hi OB;
I think the A&H is something for later. You've got clear water; you need stabilizer; you need to get your basic pool routine down; you need to learn to use muriatic acid (link in my signature); you need to be comfortable operating your pool . . . and THEN we can look at doing lime softening, which is tricky.
Among other things, you'll have to be ready to vacuum out all the calcium, which will mostly end up on the bottom of your pool.
For now, if you just keep your pH at the low end of things (with muriatic acid), and do NOT use cal hypo as a sanitizer, you should be able to operate just fine.
Later, once I'm a little caught up here on the forum, and once you are comfortable operating the pool, and controlling the basics, THEN we can make it really complicated for about a week.
