Thread: Vacuum hose coupler
    May 2012
    Tennessee
    Default Vacuum hose coupler
    What do you use to seal the coupler to the vac hose? Just put a new one on and get air leaks at skimmer end.
    TJG
    Default Re: Vacuum hose coupler
    What "vac hose" do you mean?
    I use that term to refer to a vacuum hose, used with a pole and a vac head, to vacuum the pool. But I'm guessing you mean something different.
    May 2012
    Tennessee
    You are correct. I was having air leaks at both ends after installing new couplers. Problem was solved with the generous application of teflon plumber's tape.
    TJG
  1. Strainer / floor drain adapter for vacuum hose
    By coultond in forum Pool Equipment & Operations
    Last Post: 05-27-2012, 10:02 AM
  2. Vacuum Hose Size
    By jojasc in forum Pool Cleaning: Manual or Automatic
    Last Post: 05-16-2012, 01:14 PM
  3. Can I temporarily remove the vacuum hose?
    By Stimpy77 in forum Pool Equipment & Operations
    Last Post: 04-29-2012, 06:19 PM
  4. cracked vacuum hose cuff... replaceable?
    By leejp in forum Pool Cleaning: Manual or Automatic
    Last Post: 06-25-2007, 08:46 AM
  5. Vacuum Hose Reels.
    By caustik in forum Pool Equipment & Operations
    Last Post: 09-25-2006, 07:40 PM
