1. Don't use the Algae Guard -- I'm pretty sure it's a foamy algaecide. It will make your pool sudsy, and it's irritating.
2. Use the bicarb to raise the pH, but when it's gone, switch to 20 Mule Team borax
3. If you've got bleach, you can use that. Buy 4 - 6 lbs of stabilizer at Walmart, and put it in an old sock, hung in front of the return. It may take up to a week to dissolve.
4. Dose with 1/2 gallon of bleach each evening, and about 1/8 - 1/4 just before each use. Once the stabilizer dissolves, you'll be able to cut back.
