Thread: hello and thanks!
    May 2012
    New Hampshire
    Default hello and thanks!
    Hey all,
    I found this website by doing the old Google search(thanks Google!) I have a 18' round above ground pool. I installed it about 6 years ago. I do top it off with well water each spring and it usually turns green/blue (high copper).
    This year it turned brown and after reading on a few other websites they all said it was iron! I was a bit skeptical about that ( being familiar with the fact I have high copper not iron and it never did this before). I came to your website and the first thing you always ask is for pool readings and type of pool you have. I felt comfortable instantly with the way you give advice(not giving any until you have all the facts!)
    So I read a bunch of the posts on algae (which is what I thought I have) and found your recommendations of using bleach instead of pool companies chemicals, well i have put 2 gallons of shock in the pool in the last 2 days and tried the bleach today. About 2 hours after I put in a gallon of bleach the water has turned from brown to the usual blue green that I normally deal with when opening the pool. I know I jumped the gun with self diagnosing the problem from reading other peoples problems but I guess I got lucky...
    I plan on buying a proper water tester from your recommended site and plan on contributing to the website(it would have been the $ i spent at the pool place to clear up the algae problem). I am anxious to look around the rest of the site to see what else I can do to get better pool water quality. So once again I say thank you!
    May 2012
    New Hampshire
    Default Re: hello and thanks!
    Hi, Steve, and welcome to the Pool Forum. Hope you enjoy being a part of it!
    Thanks watermom! I cannot get access to any of the forums and links on the bottom of your post. Do you know why?
    Thanks,
    Until your registration is complete, you'll need to log out to be able to see the rest of the forum and links. Only a temporary inconvenience, however.
    Registration upgraded. Ben
