Also, something is buggy with this forum.. believe it or not, I think sometimes when I hit the post quick reply button.. instead of getting the "wait for a moderator to review" message.. I get nothing.
24' Round 52" (44"/12450gal) Deep Namco Morada - ClearWater 22" Sand Filter - 1.5HP (SPL) Speck Pump - Taylor K-2006C Test Kit
I looked at the link but I also can't read the label to know for sure that it is only CYA and nothing else. It is probably fine, but I think I'd buy from someone else where I could be sure that there is nothing in there except cyanuric or isocyanuric acid.
It's not throwing errors that I'm forced to check, right now . . . so I'm not gonna. We're absolutely swamped with new users, plus I've got some major software upgrades in the works, so if it's not breaking something serious, I'm not getting out the digital backhoe, and hunting for it.
But, if you want to see if something breaks, try this: http://www.poolforum.com/pf2/showthr...6278-Pool-Info Once I have it fully tested, completing it will be required of all active posters. By the way, you will NOT be able to post in that section.
With respect to the Namco product, I followed the link and have no quick way to tell. I'm not going to dig right now, to see if it's the same. Where we (the PoolForum and I) are probably going is to ID a few sources of decent product that may be available locally PLUS links to Amazon product we know (or as close as I can get) is OK. There are just too many blends, labels, re-labels and name games for me to try to look at every stinking product and even annual revisions. Even when I have SwimmingPoolResearch fully operational, the MSDS and product sheets there will be the most recent available to us . . . but that does NOT guarantee that a company has not pulled a switcheroo on products, like cyanuric acid, that are not EPA regulated.
Bottom line: you're own your own with the Namco stuff. I haven't seen blended (diluted!) granular cyanuric acid yet, but I'm bet it's out there!
PoolDoc / Ben
Yeah there is at least 2 missing posts from me. One if which describes what the cya I got contains. Label says cya and sodium bicarbonate but has no percentages. Is that OK?
Other part of that post was about shock at the pool store. 12.5% sodium hypochlorite gallons for 2.99. Which is the dame price I get 6% bleach for. Any reason to just not buy the liquid shock? Is it goop? Doesn't list any other active ingredients.
I would just look for CYA that has cyanuric acid (or isocyanuric acid) only. What you bought also has baking soda in it which will also raise your alk. Your alk is a little low and could stand to come up some but I have no way to know how much. The pool shock that is 12.5% sodium hypochlorite is fine. That is the same thing as bleach but just at at a higher concentration, and that would be a good price for it.
I fat fingered that price if shock.. its actually 5.99. So in reality I would be getting .5% free over my 3 dollar gallons of bleach.
My alk was a bit low so ill add 2 lbs and see what happens. Stupid pool store has a no chemicals return policy.
If you mean, will it hurt your pool? Probably not. If you mean, should you buy it in the future? No, that's how pool companies play games to sell less for more. Is this the Namco product?
It may be a good deal. There are two problems. First, if it's not fresh, and not kept cool, it breaks down VERY rapidly at summer time temperatures, releasing oxygen gas. Second, household bleach is usually filtered for iron, but not all industrial bleach is. You can test both: add household bleach one evening, and see how much FC increases after 1 hour. Repeat with the industrial bleach. If it increases 2x as much (or is close) it's a good deal. Then, take the used household bleach, and put about a quart of industrial bleach in it. (Watch the spills: the 15% bleach I used to work with makes cotton 'evaporate'!!) Put the jug in the hottest place you can find around the hose, preferably also exposed to sunlight. Leave the lid a little loose. Check it after two weeks or so. If there's a bunch of iron sediment in the bottom, you may want to think twice.12.5% sodium hypochlorite gallons for 2.99, which is the same price I get 6% bleach for. Any reason to just not buy the liquid shock?
PoolDoc / Ben
Yes same as I linked to before. I won't buy again. Any idea how much of this mix I will need to get to 40ish cya. I would guess the whole thing eventually lol.
Too much work to test that shock.. ill stick with the Walmart or target bleach.
I'm going to finally call my pool clear!
I overshot my borax addition though.. pH is between 7.8 and 8.0. My pool tends to loose pH so I'm going to let it sit and see what happens.
Again, any idea what dosage I should use for that Stabilizer and Conditioner? Start with a pound or 2? Directions say to mix into bucket full of pool water and dump around the pool. Should I follow that or do the sock method recommended here?
EDIT by Watermom to merge 2 posts in the mod queue:
Actually reading on line that 7.8 to 8.0 makes chlorine ineffective.. maybe ill add some water tonight and put in a lil bit of pH Decrease.
Never ends.
