The Whisperflo is a powerful pump even at 3/4 HP so it will probably exceed the recommended flow rate of the filter. However, the 3/4 HP uprated SuperFlo (SF-N2-3/4A) will produce around 47 GPM on 1.5" plumbing which would be close to ideal.
BTW, which sta-rite model number do you currently have?
