Re: Taylor Fas-DpD Test Kit K-2006
Well, here's what has happened, after this original posting I went out and shocked the pool with roughly 30+ bags of Burnout 3 per the pool store as they felt I had a "chlorine Lock". At that time my readings per the pool store were:
temp-74
saturation index .8
TDS 900
CYA 31
Tot. CH 6
Free CH .7
Ph 8.4
TA 135
total hardness 199
Phosphates @ 500 PPB
After I super chlorinated most of yesterday, I awoke this morning and took the following readings:
Fc 5.2
cc .4
TA 111
Cya .....lower than my test would register
CH 250
Water temp 74
Ph 7.1
S/I .4
The pool is still cloudy, I believe there is dirt still on the bottom but I cant see it to clean it properly. By the way the pool is 20x40 I/G w/ vinyl liner.
I have spent so much in chemicals already and the season is just begun.
