Results 1 to 8 of 8
Thread: First start with K-2006
    Apr 2012
    Northern NJ
    Default First start with K-2006
    Hi folks--
    Well my kit came and I'm opening the pool. Water was nice and clear with some sediment on the bottom.
    I started with 2 lb. of dichlor shock powder, and got 8 FC w/.2 CC (almost non-existent).
    PH was very low <7, and took 12 drops of base test to raise it to about 7.4.
    TA was 20, so I added about 9lbs Arm & Hammer and. Brought it up to about 90.
    CYA was 30, and then up to 40 the next day.
    I've added Borax for the PH, but haven't retested since I applied it.
    Am I on the right track?
    --Thanks
    above-ground 15'x30'x3.5' oval -- Hayward 1.5hp Power-flo matrix, Vari-Flo XL -- Swim Pro 3.2 sft sand filter, 250# of sand
    Default Re: First start with K-2006
    Yeah, but don't worry about the alkalinity, till everything else is fixed.
    Dichlor will raise your CYA level rapidly, so be careful. Use plain 6% bleach when you can.
    Apr 2012
    Northern NJ
    I forgot to add that I usually use the Costco's 3" tabs for maintenance. I have to use tabs because I'm out of town ALL THE TIME, and my wife doesn't want to mess with chemicals. I see that they have a little bit o'copper, but I've still got most of the bucket left from last year. Any big problems with me using it up this season?
    We didn't have any green hair last year. :-)
    DuPont Trichloro-s-triazinetrione 93.5%
    Copper sulphate pentahydrate 1.5%
    Apr 2012
    Northern NJ
    Ok, guess I'll have to go shopping then. Any body have any tab recommendations without extra junk?
    Vtatt;
    It's hard to dispose of chlorine tabs legally, except via your pool. If you didn't have problems with copper staining or green hair last year, I'd recommend that you DO use the tabs up, but VERY carefully, also using of bleach (added to the pool) as a chlorine source, to keep the copper levels down. Also, put the tabs in the skimmer, not in a floater. That way some of the copper will end up staining the dirt in the filter, and then being washed out.
    Because of the copper in the backwash, be careful where the backwash goes. You do NOT want it to go in a stream, where it could kill things.
    Also, in addition to using a mix of bleach (to shock, added to the pool, not the skimmer!), use borax to push your pH up toward 7.8. This will also help remove the copper on the filter.
    Also a CAUTION: your low pH helps keep copper soluble. You may have a LOT of copper in the water, now. When you raise the pH, the copper will tend to come out, causing stains. If you can get a copper test done, do so. If you've got copper in the water, do NOT raise the pH yet, at least not beyond 7.2, and do NOT start using the tabs yet. Instead, get a liquid stain / scale product, and dose your pool with it. It will temporarily keep the copper soluble, but then will break down slowly. If you run your filter 24/7 and gradually raise the pH, the copper will tend (no guarantees) to come out on the filter.
    Alternatively, you can buy the CuLator product:
    1 ppm Culator, direct from Amazon
    1.5 ppm Culator, sold by Amazon, shipped from Periodic
    4 ppm Culator, sold by Amazon, shipped from Periodic
    We *think* these work but haven't absolutely established that yet. The company claims the CuLator will remove the copper, even when it's sequested by a liquid stain scale product. If you get the CuLater, you probably want to use it with this:
    Poolmaster 16242 Poolmaster Skimmer Basket Liner
    to keep it from being ruined by pool goo. (Put the CuLator UNDER the skimmer sox!)
    Finally, if you DO get the CuLator, do NOT put chlorine tabs in the skimmer with it -- we're not sure what would happen. Instead, put them in another skimmer (if you have two) or in a floater.
  1. Help with K-2006 results
    By Ohio Canoe in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-20-2012, 02:58 PM
  2. Using the K-2006
    By Manslick in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-07-2011, 11:31 AM
  3. Sand filter changed @ start of season ? HIGH PRESSURE @24 PSI FROM START
    By timmygreene in forum Pool Equipment & Operations
    Last Post: 05-21-2010, 07:48 AM
  4. You helped me in 2006 and now I need you again
    By Sunny32504 in forum Dealing with Algae & Slime
    Last Post: 05-27-2008, 03:55 PM
  5. Reagents for old K-2006
    By KirstenHW in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-22-2006, 03:22 PM
