Thread: set in above ground??
    May 2012
    Default set in above ground??
    we are in the process of getting an above ground, 24', discovery pool. my husband would like to set it atleast 1' in the ground, but the sales man discouraged it. any advice and thoughts on it?
    b2001 is offline Registered+ Thread Analyst b2001 0
    Dallas, Tx
    Default Re: set in above ground??
    My neighbor had his above ground pool put 2' into the ground. I liked it and did the same with my 18' x 36' above ground pool - 2' into the ground. That was 10 years ago. My pool is still all original - original liner. No doubt the pool siding would last longer not sunk into the ground - mine does show signs of rusting.
    I'm sure you've thought of thee things:
    Do you have a way to get rid of the dirt? Do you have a way to get a bobcat into your back yard? etc.
    What's the sales person's objections? Have you talked to the construction folks? How do they feel about it? If they don't feel comfortable with it, then I wouldn't either.
    They do not recommend that AG pools are buried in the ground as the walls are more likely to rot/rust/deteriorate. I think it may void the warranty, but not sure about that.
  1. Whats the difference between in ground and above ground sand filters ?
    By sherriemoseley in forum Pool Equipment & Operations
    Last Post: 05-26-2012, 01:31 PM
  2. Filling our NEW AGP now, but need help with ground wire/ground field?
    By TheVanDams in forum Above-Ground Pool Construction & Repair
    Last Post: 06-23-2011, 11:38 PM
  3. Above ground pool ladder - ground had to be leveled 1' down in yard
    By lori0479 in forum Above-Ground Pool Construction & Repair
    Last Post: 06-21-2011, 01:50 PM
  4. Investigating partial in-ground/on-ground pool
    By jcmjrt in forum Above-Ground Pool Construction & Repair
    Last Post: 07-23-2006, 06:31 PM
  5. In ground vs. above ground solar panels
    By scottturner in forum Pool Equipment & Operations
    Last Post: 05-08-2006, 02:49 PM
