Thread: Pool startup problems.
    May 2012
    Northern Illinois
    Default Pool startup problems.
    Ok, so we have a 15' X 42" steel frame, soft sided pool. Not sure if it's an Intex or what, it's whatever Kmart sells. It was great all last year but this year upon start-up we're having problems. The cover blew off during the winter and I never put it back on for lack of help. I did notice that algae had apparently started to grow in it during the fall and the water had turned a brownish/red by spring. I was told that the color had to do with iron in the water reacting with the algae and that I would need to shock the pool to kill the algae (which I thought would have died over the winter) and let it fall to the bottom for vacumning.
    I shocked the pool and the red went away and was replaced by greenish/blue. I thought I was on the way to a clear pool. According to the test strips, the hardness is very high so I need to adjust for that and I am trying to get the pH under control......it is high.
    The problem i am having now is extremely cloudy water. I don't know if it is suspended particles or a chemical issue. I don't have a vacumn so I ahave been spending hours with a pole skimmer. I got plenty of crap out, some dark slimy stuff as well as some white stuff. I believe I have most of that out but I can't see to the bottom.
    I am lost as to whether I should continue with the filtering and chemicals or just drain it and start from scratch.
    Please help and if anyone knows of a decent vacumn that would be appreciated too.
    Default Re: New member with problems.
    Cleaning up a small Intex like that is a lot of work. Your pool is only about 4,000 gallons.
    If I were you, I'd check to see what it cost to drain and refill. If it's too much, we can help you clean up.
    May 2012
    Northern Illinois
    Yeah, I'm leaning toward draining it myself. Just out of curiosity, what would you recommend to do to clean it up? I have been needing to rinse and rotate the filter every couple of hours because I get a nasty brown film on it.
    thanks.
    4K gal 15' X 42" steel frame, soft sided pool; PF:30
    1. Get a good test kit, and find out what's in there AND what's in your fill water.
    2. If you have suspect fill water, do a WHITE bucket test on the fill water.
    3. If practical (based on testing, and bucket test), chlorinate the heck out of it.
    4. Get high quality Unicel cartridges to replace the low quality (have to clean and then toss) OEM cartridges.
    5. See if the goo can be settled and then vac'd to waste using a manual vac and siphon.
  1. Pool problems on startup
    By stma in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-04-2013, 12:56 PM
  2. Crazy Cat Lady's Pool problems on startup
    By crazy cat lady in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-21-2013, 02:17 PM
  3. Vinyl pool startup
    By Bedwards01803 in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 06-10-2013, 08:34 PM
  4. New Pool Startup
    By stuckpipe in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 03-06-2011, 09:23 PM
  5. New Pool Startup - Help
    By under_h2o in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-28-2006, 04:35 PM
