Results 11 to 13 of 13
Thread: Skin rash
    Default Re: Skin rash
    Just a guess, when using the Enjoy (which does contain copper) you were not testing your water, correct?
    I will also guess that when you tried bromine you were also not testing your water or you would not have had the problems you listed in the first post.
    Once you get your K-2006 post a full set of test results
    May 2012
    Rhode Island
    We put the generator in, I corrected the ph and alkeline and I haven't gotten the rash yet and I have been in the pool 3 or 4 times which is a miracle. I don't know if I will ever know what caused it but I hope that things stay this good!! I'm so happy after going through this for 5 + years!
    Just be VERY careful to avoid ANY chemicals, if you don't know EXACTLY what's in them. That pretty much rules out all pool store and Walmart chlorine labeled for pool use, and especially, all "non-chlorine" shocks!
  1. Purchased new house pool causing redness on kids skin
    By dausmus in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 04-13-2012, 02:34 PM
  2. After adding Borax, water is drying out skin.
    By Willjay in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-19-2011, 10:38 AM
  3. Clear skin like substance on pool surface.
    By freddyttt in forum Dealing with Algae & Slime
    Last Post: 05-30-2008, 09:37 PM
  4. Anyone heard of Vinyl Magic or Perma-Skin?
    By tybeeware in forum In-Ground Pool Construction and Repair
    Last Post: 05-23-2006, 07:59 AM
