Re: Skin rash
My bet would be high combined chloramines, which also are known for eye irritation and that chlorine smell you smell when walking around a pool with inadequate chlorine levels. The kit we highly recommend is the K-2006, which can be bought online at a good price using the Amazon link in my sig. It will test both chlorine and combined chlorine levels. You also might want to check out the link to the "best guess chlorine chart" while you're at it, and it should explain proper chlorine levels being determined by CYA.
Welcome to the forum!!
Oh, until your registration is complete, you might have to log out to be able to follow those links, but once your registration is upgraded, that will no longer be necessary,.
