Results 1 to 10 of 13
Thread: Skin rash
    Default Re: Skin rash
    Yes to getting a K-2006. What kind of filter do you have? Did you change out your filter media?
    If you don't mind, would you please put your pool's information in our pool chart. It makes it easier for someone here to help.
    Pool Chart Entry Form
    May 2012
    Rhode Island
    I completed the pool chart the best I could. I have a sand filter and have not changed it out yet. We were going to change it when the generator is put on. does that make sense?
    How are things working out for you?
    Just a guess, when using the Enjoy (which does contain copper) you were not testing your water, correct?
    I will also guess that when you tried bromine you were also not testing your water or you would not have had the problems you listed in the first post.
    Once you get your K-2006 post a full set of test results
    May 2012
    Rhode Island
    We put the generator in, I corrected the ph and alkeline and I haven't gotten the rash yet and I have been in the pool 3 or 4 times which is a miracle. I don't know if I will ever know what caused it but I hope that things stay this good!! I'm so happy after going through this for 5 + years!
    Just be VERY careful to avoid ANY chemicals, if you don't know EXACTLY what's in them. That pretty much rules out all pool store and Walmart chlorine labeled for pool use, and especially, all "non-chlorine" shocks!
