Results 11 to 16 of 16
Thread: Filling a small pool with iron well water
    Default Re: New Pool
    You can definitely just use bleach if you want but if you do, you'll have to add some CYA separately which would be fine.
    In your small pool, each quart of 6% bleach will add about 2.3ppm of chlorine. Until you get some CYA in there, the chlorine will disappear fast especially on a hot sunny day. I'd add a couple quarts and see if that will give you enough to make it through the day without it all disappearing by evening.
    If you decide to go this route (bleach) you'll want to add some CYA to an old sock and hang it in front of a return jet. 2 lbs. of it would give you a reading of about 40ppm which would be good. If you give the sock a squeeze every once in awhile, it will dissolve faster. But, if you do add this CYA separately, you won't want to use the trichlor pucks or dichlor shock powder since they both have CYA in them. When you buy it, it may be labeled as stabilizer or conditioner. Check the label ingredients. You want cyanuric or isocyanuric acid.
    May 2012
    Indiana
    Will the iron and other metals in the well water affect the bleach or cyanuric or isocyanuric acid or will they affect the ability of the iron to filter out of the pool?
    Iron doesn't affect much of anything, except pools and swimsuits -- those, it turns brown or orange. But it's harmless to people and doesn't really interfere with the chemistry. It CAN make the pool very cloudy.
    If you are already up and running, do all these things, and you may find you can operate without lots of complexity:
    1. Keep your pH on the low end of the scale (7.0 - 7.4) -- this minimizes the problems with iron.
    2. Run your filter a lot, and keep the cartridges clean.
    3. Very carefully, use a liquid clarifier, to help your filter remove the iron as particles form.
    4. Try to avoid adding a lot of chlorine all at once -- it tends to make the iron drop out all at once. Raising it gradually is better.
    5. As soon as you have a complete set of test results, please post them.
    May 2012
    Indiana
    Thanks! We are using or trying to use BBB method. Just adding a little bleach every day. Today the water temp got up to about 70 degrees so no one has used it yet. We'll get a clarifier in and I will try to post some results tomorrow. Thanks for your help..
    May 2012
    Indiana
    Test results today were pH 7.2, Chlorine 5, TA 220 (I added 17 drops and it was starting to turn red added more and it was mostly red when I got to 22 - I am new to testing so I'm just going by what the paper said to do). Should I add borax to lower the TA? How much?
  6. #16
    If you would, please enter your pool info in this form:
    Pool Chart Entry Form
    Pool Chart Results
    Makes it much easier for us to give good answers.
    + Borax doesn't lower TA; it raises pH. Right now, you don't need to raise pH OR lower TA.
    + Filter, filter filter.
    + Don't let your chlorine get below 2 ppm.
  1. Water problems in small, small pool
    By MikeFromMesa in forum Pool Chemistry for Intex-type Pools
    Last Post: 06-10-2013, 04:53 PM
  2. Pool is filling - tap water results.....
    By court475 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-21-2006, 01:51 AM
