Results 1 to 10 of 43
Thread: use of liquid chlorine in AG vinyl lined pool
    Default Re: use of liquid chlorine in AG vinyl lined pool
    TC = FC + CC. Always. With a CYA of 70-80, you need to be shocking up to 20ppm. Adding 4 big jugs would have added 45ppm! Way too much! So, what is really happening in your pool is that you have so much chlorine, that you are probably bleaching out the DPD test and it appears that you have none!
    Don't add anymore chlorine at this point. Use a dilution test to see if you can get a better reading. More about that here: Testing Without a Good Kit
    Your pH test will be inaccurate with high chlorine. But, typically with high chlorine, you get a falsely high pH. So, I'm going to suggest going ahead and adding a half a box of Borax slowly to the skimmer while the pump is running.
    You do not need a new filter, but your pump is WAY oversized for your small pool. We see this a lot. When a pump is too big, it forces stuff through the sand bed without filter it out well. Thus, it can take a long time to clear a pool.
    Repost with the dilution test results. Also, if you can, order that K-1515 add-on kit I mentioned above.
    May 2012
    Florida
    i had a CYA of 70-80 a few days ago, but today i dont even reach 100 before the black dot goes away. i didnt add all 4 jugs of bleach last night, just 1 jug. i will try the dilution test tomorrow after work. my pool doesnt have a strong chlorine odor at this time, actually very little chlorine odor. i will order the K-1515 tonight. my filter doesnt use sand its just a plain old cartridge filter. i was talking with my wife and the filter is actually two years old... oops. i never had a cloudy water problem before, so im going to order a new filter tonight just to rule that out. ill keep my current filter as a back up.
    thanks for the help!
    Then, your CYA is over 100. Try the dilution test on this one, too, to try and see if you can't get a little closer reading. Dilution isn't super accurate, but better than nothing.
    Why is your CYA climbing? Have you added some recently and if so, when and how much? Or are you using a stabilized form of chlorine such as trichlor tabs or dichlor shock powder?
    Glad to hear you didn't add all that chlorine at once!
    May 2012
    Florida
    Default
    i was able to do the chlorine dilution test and the color was a very light pink color. i used 1 part tap water and 1 part pool water and 5 drops each of R-001 and R-002.
    i was using both trichlor tabs and dichlor shock but have stopped using them. i will try the dillution CYA test and post back. i will need to get more R-0013 since i only have one bottle left.
    i just ordered the K-1515 and a new filter, thanks again for the help!
    BigDave's Avatar
    I'm concerned that you have no chlorine in your pool and you're in another algae fight. I'm sorry to disagree with you watermom.
    If you read this before leaving work, please pick up a cheap OTO/pH test kit on your way home. It wil definitively tell you if you have lots or no chlorine; OTO doesn't bleach out. If your wall mart has the HTH 6-way kit (check availability), get that, it will supplement your K-2006 and give you an OTO kit as well.
    If you have no FC, you need to get to shock level (25ppm+) and keep it there until you have less tham 1ppm loss of FC overnight and 0.5ppm or less CC.
    Two big jugs (1.42gal) of 6% bleach should get you near 25ppm.
    When I advised not to add any more bleach at that point it was because I thought all 4 big jugs of bleach had been added at once. If that had been the case, the DPD test would have been bleached out and thus reading 0 chlorine. After I wrote that, the OP clarified in a later post that all the jugs were not added all at once.
    May 2012
    Florida
    i added approx 2 lbs of borax this monring before work since it was low ( below 7.0 ) tested after work and PH is was 7.2 so i added the rest of the box or borax approx 2 more pounds and retested an hour later PH is now 7.6
    FC is still 0. i also did a diluted CYA test by mixing 1 part tap water and 1 part pool water for the test. i put 7ml in the small bottle and then added 7ml of R-0013, mixed for 30 seconds and got a reading of 70 at the time the black dot disapeared. so this tells me i have high CYA right?
    i just added 2 big jugs 2.84 gal total to the pool. i also noticed big brownish/green splothces on the pool floor so the battle goes on! water is still cloudy.
    i will test FC after dinner if it doesnt start to down pour, and ill be heading to walmart later for more chlorine and borax. i know my local walmart doesnt have the kit bigdave mentioned at this time as i looked for it before picking up the K-2005 i just bought.
    the good news is my K-1515 and filter shipped today! am i basically making my K-2005 a K-2006 by adding the K-1515?
    BigDave's Avatar
    WM; you are (of course) absolutely right. I just noticed that Darkside had a legitimate FC of 0 and hadn't added any chlorine since. I hope I haven't offended you.
  1. SWCG for vinyl lined pool with steel walls?
    By windypool in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 05-20-2012, 11:54 PM
  2. In ground vinyl lined pool chemical imbalance and black algae
    By clrrak2 in forum Dealing with Algae & Slime
    Last Post: 07-25-2011, 06:02 PM
  3. Help with Stains in Vinyl Lined Inground PLEASE
    By btozzo in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 07-25-2010, 10:11 AM
  4. Stains in my vinyl lined pool
    By MartyW in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 07-31-2006, 08:17 PM
  5. Gunite -vs- Vinyl lined
    By Pool_Mike in forum In-Ground Pool Construction and Repair
    Last Post: 06-12-2006, 03:51 PM
