Re: use of liquid chlorine in AG vinyl lined pool
i added approx 2 lbs of borax this monring before work since it was low ( below 7.0 ) tested after work and PH is was 7.2 so i added the rest of the box or borax approx 2 more pounds and retested an hour later PH is now 7.6
FC is still 0. i also did a diluted CYA test by mixing 1 part tap water and 1 part pool water for the test. i put 7ml in the small bottle and then added 7ml of R-0013, mixed for 30 seconds and got a reading of 70 at the time the black dot disapeared. so this tells me i have high CYA right?
i just added 2 big jugs 2.84 gal total to the pool. i also noticed big brownish/green splothces on the pool floor so the battle goes on! water is still cloudy.
i will test FC after dinner if it doesnt start to down pour, and ill be heading to walmart later for more chlorine and borax. i know my local walmart doesnt have the kit bigdave mentioned at this time as i looked for it before picking up the K-2005 i just bought.
the good news is my K-1515 and filter shipped today! am i basically making my K-2005 a K-2006 by adding the K-1515?
