Re: use of liquid chlorine in AG vinyl lined pool
How does your water look? Still cloudy? Are you running the pump 24/7? Go ahead and add some more bleach. This evening after the sun is off the pool, check and see where you are chlorine-wise before adding more and then a couple hours after you add it, test again. Then, in the morning within 2 hours of sunrise, test again before adding more. We want to see if you are losing more than 1ppm overnight.
Also, just a reminder ---- Can you please make a signature line which gives the type of pool, volume, type of filter, size of pump, any other equipment you have and also the type of test kits. That makes it easier for us to help instead of having to continually scroll back up looking for details about your pool. See the link in my signature for how to do so. Thanks!
