The chlorine you're adding to the pool will kill the algae, but filtering/vacuuming is what will remove it from the pool. Have only skimmed the whole thread, so don't know if they've mentioned it, but we usually recommend leaving your pump/filter running 24/7 during this process to help filter it all out. Make sure to clean your filter as your pressure indicates....
