Thread: Solar heater - could it also cool water a little?
    May 2012
    Georgia USA
    Default Solar heater - could it also cool water a little?
    Full disclosure: I've also posted this on another pool forum.
    Here in the sunny south, near Atlanta, our swimming season is pretty long, but longer would be nice! I'd given some thought to installing the extruded plastic collectors on the south-facing roof of our pool house. The solar orientation is close to ideal, the collectors are relatively light, and the plumbing would be so simple, since the pump/filter is in the south-west corner of the building.
    Then I had an idea, a dangerous event for me! I wonder if, in addition to collecting solar energy during the day in early spring and late fall to extend the swimming season, the same collectors could circulate pool water at night during the height of summer to dump excess heat. Our pool temperature seems to approach body temperature in late July and early August, hardly refreshing. I imagine that I'd need some idea of the average low night temperature during the height of summer, and the actual water temperature. I'm not an engineer, but I suspect that the greater the temperature difference (delta T?) between the pool water and the atmosphere the better this might work. Clear nights might be more effective in radiative cooling, while cloud cover might mean only conduction to cooler air would be effective.
    A differential temperature control valve to bring the collector/radiator on or off line would be a nice though probably costly addition for either heating or cooling.
    Any engineers out there? Any one have opinions? Any experience with the roll out collectors?
    BigDave's Avatar
    Default Re: Solar heater - could it also cool water a little?
    My solar panels were installed with a Gold-Line GL-235 controller which controlls a valve that directs the water to the panels when the panels are warmer than the water and the water is cooler than the temperature setpoint. It will also send water to the panels when the water is warmer than the setpoint and the panels are cooler.
    Sep 2010
    it won't cool nearly as good as it heats (btu-wise) but as long as the air temperature is cooler than the pool water temp the solar array will act somewhat like a car radiator. The greater the temperature difference the more effective the cooling will be.
    27' Esther Williams above-ground
    May 2012
    Georgia USA
    Many thanks for the opinions.
    I'd guess that, just as copper or aluminum collectors would be more efficient in gaining solar energy they'd also be more efficient in shedding heat. Of course if I had access to a large number of truck radiators and fans....
    But metal collectors would be far, far more expensive, and there'd be a greater risk of freeze damage as opposed to the plastic sort. Do any of you users out there have drain-down provisions for frosty nights, or are the collectors pitched so that they drain themselves?
    BigDave's Avatar
    They should be installed to drain back. The GL-235 has a freeze protection option that will run water through the panels when temp gets near freezing to keep them from freezing and bursting.
