Results 1 to 10 of 38
Thread: Moblaine's pool
    Jul 2011
    Hinesburg, VT
    Default Re: Moblaine's pool
    Hi Ben, I will re-test tomorrow and add results. I tested for copper today and had none so will add those results to the chart.
    Can you explain to me - Do I need to worry about the copper/Ph thing if I don't seem to have a copper problem?
    Also, I am confused about the Frog question - are we both talking about the products from King Tech? A friend of my husband's installed our pool (he's in the installation business but doesn't sell chemicals). He has us using the same things he uses. Every year I insert a new Mineral Reservoir into the Frog but instead of paying an arm & a leg for their Bac Pacs, I just cut the bottom off and fill them with 1" or 3" tri-chlor tabs. What are the side effects you mention? Wouldn't the tri-chlor tabs BE a sanitizer? I apologize if I'm being slow to catch on here, it can be overwhelming. Thanks for your help.
    16'x36' rectangle 21K gal IG vinyl pool; Trichlor feeder; Hayward DE 4820 DE filter; Pentair Superflo VS pump; 12-14 hourshrs; Taylor K-2006; delivered via truck; summer: solar; winter: mesh; ; PF:4.8
    Quote Originally Posted by moblaine View Post
    No. If you have 0.0 ppm copper, it's not an issue.
    You're not 'using' the Frog, your 'abusing' it!
    The mineral reservoir has copper in it. But I don't think it always succeeds at adding copper to the pool (in other words: it fails to work, which is good, but expensive).
    You're sort of working around their program, using their feeder. You need to watch out for staining when you replace the mineral pack. However, if you are just using the plastic cartridge as a holder for your own tabs . . . why do you need a new one?
    Jul 2011
    Hinesburg, VT
    Good point - what are the disadvantages to not using a mineral reservoir?
    Also -you mentioned earlier adding "3 gallons, per 10K gallons of pool water, of PLAIN 6% household bleach each evening. Use an OTO kit to test before re-dosing; if you get a DARK yellow value in the evening, skip that dose."
    Question: Is it put in during evening so that it can work without sunlight affecting it? I'm anxious to put it in now but can see the wisdom in waiting until tonight. It's supposed to rain heavily & possibly hail today, does that make a difference? Now that I have the K-2006 as opposed to using the OTO kit you mentioned, at what measurement do I stop putting in the 6% bleach? I just went to Wal-Mart & 2 large grocery stores in the nearest "city" and bought all the large containers of 6% bleach I could find. The price worked out to about $2/gallon but liquid chlorine can be bought with 12.5% from local hardware store for $4/gallon. Seems like the price is equal or am I missing something?
    Borax was hard to find but I did locate 4 boxes at a grocery store. Is this also pertinent to add at night?
    BigDave's Avatar
    You're right the 6% at $2.00/gallon and the 12.5% at $4.00/gallon are basically the same price per pound of chlorine. If you're clearing the shelves, there's no loss in clearing the 12.5% as well as the 6%. use the 12.5% first 'cause it won't last as long.
    FWIW - my opinion - get rid of the Frog. At best, it will add copper which will cause you a problem later. Just say no to metal(mineral) algae control. It doesn't kill fecal coliform, only algae. We can eaisily see when algae gets out of control, but, butt bacteria you can't see, but, it'll make you really sick.
    Jul 2011
    Hinesburg, VT
    I contacted King Technology -- they tell me there is NO copper in their Mineral Reservoir. What do you make of that?
    image and quote from: http://www.kingtechnology.com/produc...s-poolfrog.htm; archived 7Jun2012
    The POOL FROGŪ Mineral Reservoir, which contains our EPA registered mineral formula and fits inside the Cycler. The minerals continually replenish themselves for added protection against bacteria, as well as keeping your pool's pH balanced by acting as a neutralizer. One Mineral Reservoir will last the full season or up to 6 months; use two reservoirs for year-round pools.
    In the pool industry, the term "minerals" has been applied to three things: copper, silver, and zinc. At effective levels, copper kills algae, inhibits bacteria a little, and stains hair and pools. At effective levels, silver inhibits algae, kills some bacteria slowly, and stains pools gray or black. I've seen no evidence to date that zinc can be added to pools at levels that are effective at anything . . . but it doesn't stain.
    I'm going to try to look up the King Tech EPA registration, but it may be they've revised it to remove copper (which stains) and silver (which stains and is expensive) and left zinc (which AFAIK does nothing much). This allows them to keep the claim "minerals", charge more, and still not stain your pool. Of course, if they DON'T have copper or silver, then the question would be, why replace the unit . . . EVER?
    Ok, I found it (below)
    -- the mineral pack is 99.5% inert and 0.5% AgCl, silver chloride. Now, that's interesting: silver chloride is not likely to stain your pool, because it's so very insoluble in water. The "efficacy" data (last link below) is also very interesting: in a glaring typo, not only does it ID the effective agent as "0.5% sodium chloride" (salt) in the front of the report, the efficacy data appears to me to show that the added silver has ZERO effect on sanitation.
    I'm going to ask Chem_Geek to take a look, and see if it looks as weird to him, as it does to me; he's much more familiar with EPA registration standards.
    But it appears to me that, when you purchase a "mineral reservoir", you are buying a product that's almost perfectly safe to use . . . because it does almost nothing!
    Just a caution: this discussion is likely to get into deep technical waters, resulting in this thread moving to the "China Shop" section.
    Found it:
    http://iaspub.epa.gov/apex/pesticide...PLS:4:0::NO::: - King Tech index
    http://iaspub.epa.gov/apex/pesticide...EG_NUM:53735-2 - Trichlor pack
    http://iaspub.epa.gov/apex/pesticide...P8_PUID:463787 - Mineral reservoir
    http://www.epa.gov/opp00001/chem_sea...7-Oct-06_a.pdf - Efficacy data
    All reports archived 07 June 2012 @ SwimmingPoolResearch
    The efficacy data says "The product must be used in conjunction with an EPA-registered source of chlorine (such as Chlorine Bac Pac)." They amended the registration for use in spas and bromine may be used in place of chlorine. They did their actual tests using the equivalent of what would occur from the use of bromine tabs (BCDMH) with their product with 1.3 ppm BCDMH with 2.6 ppb silver ions. The lab results supported use of the Spa Frog with bromine in the 0.9 to 2.25 ppm range. The EPA approved their label which has 0.5% silver chloride as the active ingredient to claim disinfection and the use of chlorine or bromine at 50% of the levels they would be used at by themselves. So instead of 1 ppm FC or 2 ppm bromine, it's 0.5 ppm FC or 1 ppm bromine. Note, however, that their claim that it reduces chlorine or bromine "use" by 50% is only true to the extent that ALL chlorine or bromine loss is from sources proportional to their level such as loss from sunlight or oxidation of fixed amounts of chemicals or surfaces. So IF one maintained a lower chlorine or bromine level in an outdoor residential pool, then one would use less chlorine or bromine. HOWEVER, silver ions (unlike copper ions) do not prevent algae growth so in practice one still needs to maintain a chlorine or bromine level sufficient to prevent such growth. For chlorine in an outdoor pool, this means an FC sufficient for the CYA level and that level will not be lowered at all by the presence of silver ions. The loss of chlorine or bromine from killing bacteria is too small to be measurable in test kits.
    In a spa used every day or two, it is the bather load that determines the bulk of the chlorine or bromine usage, not the minimum level of chlorine or bromine that is to be maintained. So there will be no savings when using silver ion in a frequently used spa. In a spa used infrequently, once a week or less, then one can maintain a lower chlorine or bromine level so could get a modest amount of savings in usage.
    So for an outdoor residential pool, there is no savings from using the Frog. If one wants to spend more to have "savings", then one can use an algicide. Copper ions would work to prevent algae, but can stain pool surfaces and turn blond hair greenish, but Polyquat 60 weekly would also work and let one have a lower FC target level relative to CYA and therefore save on chlorine. However, the cost of the Polyquat exceeds the savings in chlorine so this is not normally done. It only makes sense for those who want a lower active chlorine level in their pools and are willing to pay for that possibility.
    By the way, silver ions can most certainly stain pool surfaces (mostly plaster) and they are very nasty black stains. This is why the silver ion level is kept so low and why pH also needs to be controlled so that it doesn't get too high.
    I'm missing the point of the Pool Frog discussion in this thread. It doesn't provide any practical value so why is it being discussed? The only benefit of having the silver ions in the water is some level of "insurance" if the chlorine level gets to zero since uncontrolled bacterial growth will be somewhat inhibited. However, since it won't prevent algae growth it's really not that great insurance.
    BigDave's Avatar
    Ah! so it's silver.
    No, you can add Borax anytime you want...the sun doesn't break it down like it does the chlorine.
    Jul 2011
    Hinesburg, VT
    Okay, now what? Last night I put in about 950 ounces of 6% household bleach as per Ben's advice (3 gallons per 10,000 gallons). Yesterday my FC was 0.4 and so was my CC. This morning, the results are not what I expected: FC 1.4 and CC 1.8. I anticipated CC would have been lower, not WAY higher. My current course of action will be to test tonight and put in a similar amount of bleach but wondered if there were any other recommendations.
