Re: Confused Newbie needs CYA advice
Thanks so much for this. I tried it out on several brands and it worked perfectly. The Aldi bleach was 3.5 ppm, same as when I tested the pool after adding it. Kroger bleach was exactly 6 ppm. I will definitely be doing this test on one bottle before I go buying 20 of them.
15x28 rectangle 13K gal IG concrete pool; trichlor tab in chlorinator tube; Hayward 190 cartridge filter; 1.5 HP Hayward Super II pump; 12 - 24hrs; K2006; utility water; summer: none; winter: none; ; PF:9.2
