Results 1 to 10 of 14
Thread: Cloudy Water!!!!
    Jun 2012
    Illinois
    Default Cloudy Water!!!!
    Opened my pool it was green and slimey!!! Cleaned the pool and shocked it and now it's cloudy blue. Reading some posts and it say's to keep the chlorine and whatever the CYA PPM is. I'm at 30 to 50 PPM and my Chlorine is around 15? Do I keep it there until it starts to clear? I have a 33 Round. I have the HTH 6 test and my 2006 test kit should be coming. The test shows FC at 10/20 Bromine but it doesn't register higher How do I know that I'm high enough. By the way I'm using the bleach now.
    Default Re: Cloudy Water!!!!
    Yes. Keep the chlorine at about 15 as consistently as you can. Until your K-2006 arrives, you can use a dilution method to force your kit to read higher. It's not super accurate and not meant to replace having the good kit, but better than nothing for now. Testing Without a Good Kit
    What kind of filter do you have and what size of pump? By the way, ignore the bromine reading since you have a chlorine pool. Hope this helps.
    Welcome to the Pool Forum!
    Jun 2012
    Illinois
    received my test kit my numbers are fc=15.6 to 20(this morning) I added gallon of shock just using what i have left last night.
    c.c-.5
    ta=170
    ca=280
    ph=7.5
    cya=45 ppm
    Sand filter = swim pro model #sw256t pump 1081 sp151521bc ? motor 1.5 hp
    Its still cloudy how long do i keep it at the levels? Do I still run the filter non=stop Pressure is good should I vacuum the pool? If I should do I set it at filter or waster I think filter because waste would mess my reading? How much bleach do you normally ad to a 33 round? 1 gallon equals what?
    thanks for your help!!!!!!!
    I'm guessing your volume is about 26,000 gallons, so each gallon of 6% bleach would add about 2.3ppm of chlorine. Use that as a reference to help you figure out doses.
    Since it is still cloudy, I'd continue to keep the chlorine high (around 15) and continue to run your pump and filter. Is your filter pressure rising?
    Is there anything to vacuum up? If so, then go ahead and vac. I'd vac to the filter so you don't waste so much water. Then, you can backwash your filter if needed.
    (I would not use any more cal-hypo since your calcium hardness reading is already at 280.)
    Jun 2012
    Illinois
    o.k i'll do that. Yes my filter is rising and I backwash. What do you mean by cal-hypo?
    Cal-hypo is a form of chlorine often sold as bags of "shock." Since your CH (calcium hardness -- I think that is what you meant by CA) is 280, I assume that you have used some.
    While you are battling cloudy water, you need to be maintaining your chlorine level at 15 as consistently as you can. And, you need to do so until you have clear water, you are losing no more than 1ppm of chlorine from sundown one evening until within two hours of sunrise the next day and you have a CC reading no higher than 0.5. At that time, I'd suggest keeping the chlorine high for one more day for additional insurance and then you need to make sure that you ALWAYS keep your chlorine level between 3-6 ALL the time. If you let it drop below that, you risk an algae bloom. If you haven't already done so, take a look at the Best Guess Chlorine Chart in my signature below for the connection between CYA levels and needed chlorine levels.
