Results 1 to 10 of 33
Thread: No Chlorine at all in pool...
    Jun 2012
    Default Re: No Chlorine at all in pool...
    Well I got 2 gallon of liquid chlorine left 10% should I just use 1 gallon of that. Don't have bleach. I also have 3lbs of cal hypchl left too.
    20 yr old 23K gal concrete pool; DE filter; PF:5
    Sure. You can use the 10% or you can use some cal-hypo since you have a concrete pool and your calcium hardness level is only 160. (200-400 is the suggested range.) Either way will work.
    Jun 2012
    Had to backwash, psi was ready to hit 30 after I put the pool perfect w/phos free in. Now I'm at 11psi. I usually hover around 11 - 18 psi. Gonna throw some cal-hypo in, in little awhile. It just got real dark thunderstorm warning! Should I wait?
    What should I do about the 400 Phosphate reading?
    People get algae during rain because they stop taking care of their pools -- NOT because of the rain. Add the chlorine!
    Don't worry about the phosphate.
  1. Chlorine tabs vs chlorine bleach generic
    By Cahoonh in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-13-2013, 10:28 AM
  2. High Chlorine Level with no Chlorine Added in 6 weeks
    By morechoff in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-27-2006, 08:52 AM
  3. Free Chlorine vs. Total Chlorine adjusting
    By Truckman in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-08-2006, 06:00 PM
  4. alternatives to chlorine/non-chlorine pool maint
    By leewest in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 04-04-2006, 11:53 PM
