Thread: Which CYA test kit is more accurate?
    Default Re: Which CYA test kit is more accurate?
    It's really as good as it gets. Believe it or not the colorimeters used by some pool stores actually have less precision (+10/-25 ppm) on this test than the 'disappearing dot" and they are better then any home colorimeter
    Virginia
    Yeah, I've gotten some pretty wacky results from pool store testing. I think I'll go ahead and get the newer kit that uses a small sample size and less reagent; over time it'll save me some $$ and hassle reordering reagent.
    Thanks again for your help.
    Virginia
    I went ahead and ordered the new replacement for my old CYA Taylor test kit so I don't have to use near as much reagent. BTW, if like me you can do without the case and instruction sheet (instructions are available online on Taylor's site anyway), you can save about $17 just by ordering the parts needed from Taylor (bottle, tube, and reagent [I ordered the 2oz size]).
    Thanks again for the feedback.
