Re: New 15' x 48" Intex pool
Howdy!
My CYA was way too high - 100 ppm - so I decided to drain the pool and start over. Ugh on the water bill! Anyway, I tested today after balancing for the last couple of days and here are my results.
CYA - 10 ppm or less (still waiting for it to all dissolve)
FC - 50 ppm
CC - 0 ppm
pH - 7.6
TA - 170 ppm
CH - 130 ppm
I periodically take my trichlor dispenser out because my chlorine is so high, but I was finally able to vacuum all the algae off the bottom of the pool. My main issue right now is cloudy water. Not any particular shade (green, yellow) - just cloudy. I'm not quite sure how to fix that or if it is an effect of my high chlorine. All suggestions are welcome!
I filled out the Pool Form so hopefully it adds my details to this post. :-)
Stefanie
