My filter takes the A cartridge.
Cleaning supplies -- you can get all these locally. TSP is usually in the paint section. Any clean plastic 5 - 10 gallon bucket with a lid will work for soaking:Rubbermaid BRUTE Gray 10 Gal Container w/o Lid @ AmazonCartridge -- you need 2:
Round Brute Lid For 10-Gallon Waste Containers, 16" Diameter, Gray
1lb Savogran 10621 Trisodium Phosphate (TSP) @ AmazonUnicel C-4607 Replacement Filter Cartridge (Easy Set Size A or C) @ AmazonIf you shop around on Amazon, be very careful. Most of the products that say "Unicel" somewhere in the description are NOT Unicel, but one of a variety of Asian made products, that are NOT equal in effectiveness.
PoolDoc / Ben
Thanks for all of the help. I am now able to see across the entire pool all the way to the bottom. I have ordered the filters and will be ordering the test kits next week. We have had a lot of rain in the past week so I have been vacuuming using the siphon out onto the ground since my current filters will not trap the fine debris.
My pool is still not as clear as I would like it right now. Should I keep the FC levels high another couple days or should I let it go back to normal and see if the filters will fix it when they come in?
If your weather is cloudy, so you don't lose much chlorine to the sunlight, keep it high.
Otherwise, if you can only measure to 5 ppm, let it drop just below 5, and then re-dose to take it to near 10 ppm, till you have a kit, and can manage it more accurately.
PoolDoc / Ben
How do you use the TSP? I have 2 c400 cartridges that were at 8psi and now are at 20 psi even after I rinse them.
