Results 1 to 10 of 15
Thread: To shock or not to shock
    Default Re: To shock or not to shock
    Stabilizer that is 96% cyanuric acid is fine to use; normal production cyanuric has, I think, up to 5% impurities and inerts present.
    May 2012
    WA
    Good to know. Thank you!
    doughboy 24x24 AG round 16,100 gal with 3.5 and 6.5 deep end. Doughboy sand filter. Doughboy 1 hp pump. Tropi-cal 75k btu heat pump.
    May 2012
    WA
    UPATE: After our shocking the pool and adding CYA, we saw our CYA actually go up to 45. That was 2 1/2 lbs to the skimmer. That 2 days ago.
    We tested today (pool still covered with solar cover with rainy cool weather) and the numbers are as follows:
    FC 10 with the smaller volume test or 8.8 with larger. (why the difference?)Did my husband mess up?
    CC 2
    TA 80
    CY 45 ish..
    PH 7.2
    (we need to get a refill for the Taylor CYA test)
    Why did the CC go so high after shocking and adding stabilizer? Is this normal? The weather will be nice this Sunday, so we are hoping to swim. Husband says the pool does have a stronger chlorine smell this morning.
    thanks.
    Quote Originally Posted by tokmom View Post
    When you cover a pool, CC's and CC precursors -- pool goo -- can't escape. Pool goo (it's a technical term here ) consists of bad pool chemicals, sweat, pee, suntan lotion PLUS whatever else gets in the pool and reacts with chlorine. Sunlight, chlorine, and aeration get rid of pool goo. Lose the sunlight, and cover the pool with a vapor-tight cover, and Voila', you have an indoor-chemistry pool. Indoor-chemistry pools have problems with goo.
    So, while I don't know exactly where YOUR particular CC's are coming from, they aren't unexpected.
    Does that help?
    May 2012
    WA
    Ok, I wondered if the pool being covered for a good couple of weeks had anything to do with it. The sun (GASP!) has decided to make an appearance today. Maybe we will take off the cover and let it air out.
    Should we see if the CC drifts down on it's own in the next few days?
    I like the word Goo. At least I understand it, lol.
    Very likely.
    Maybe we will take off the cover and let it air out. Should we see if the CC drifts down on it's own in the next few days?
    Yes, please.
    Thanks, I prefer the sort of naming that nuclear physicists do (it's a "quark") to the sort the military and school teachers do (CRT = "Criterion Referenced Test" . . . ????) or physicians ("Doc, my skin is red and inflamed!". "Yes, you're suffering from erythema." "Wow, thanks, Doc! I never would have known." [ erythema = red & inflamed skin ])
    But, I slip sometimes. Currently, I'm using the phrase "epistemologically modest" a lot (not here, in my other life), and currently only my sons know what I mean, sorta, kinda. Unfortunately, every other way I've tried to say it takes a paragraph or more.
    Last edited by PoolDoc; 06-08-2012 at 06:03 PM. Reason: epistemolgy has two e's, not two o's, darn it.
    BigDave's Avatar
    "epistomologically modest"? Is this intended to be an insult (doesn't sound like you)? Akin to calling someone obtuse? Or do you mean the understanding and incorporation of the knowledge that one's knowledge, no matter how developed, is woefully incomplete. Leaving behind the pride one may have of his own knowldege and adopting a more humble view of one's self?
