Thread: sandpaper sides in newly opened pool
    Default Re: sandpaper sides
    Don't let the pool guy add or spray anything else at the problem.
    We are going to need some current water testing results to be able to help that are taken with a drops based kit. The kit we recommend is the Taylor K-2006 or 2006C which is listed on the test kit page in my signature below. Until that time that you can order one (not available locally), see if your Walmart has an HTH 6-Way kit (not test strips) that you can buy. If not, get an OTO/Phenol Red (yellow and red drops) at the very least. Tell us what kit you get and post some numbers. If you can only find an OTO kit, let a reputable pool store test your CYA, alk and calcium hardness levels but don't let them talk you into buying a bunch of stuff.
    What kind of pool is this? I assume it is inground, but is it gunite, vinyl or fiberglass. Is it filled from a municipal water supply or from a well?
    Repost with requested info and someone here will try and help.
    Welcome to the Pool Forum!
    Jun 2012
    NY
    thanks watermom. I have a vinyl lined pool with fiberglass walls if I remember correctly. They are not charging me for this and they didnt charge me for the alkaline boost either (believe me I paid enough). Figure I have nothing to lose at this point but I will try and get a test kit. Thanks
    Wow! The weather this year is bringing out all sorts of fairly rare events. It sounds like you had 'sand algae' -- under certain conditions, slime layers with algae and bacteria can deposit calcium carbonate particles that look sort of like sand particles glued to your pool. I'm gonna post these pics for the 2nd time today; usually I post them about twice in an entire season!
    Rather than reposting everything, I'm going to ask you to read this post: http://www.poolforum.com/pf2/showthr...2469#post92469
    But, please respond here, rather than in that thread. It gets REALLY messy if we try to help two people with different pools in the same thread!
    By the way, like Mom said, do NOT let them put ANYTHING else in the pool, especially anything that will increase calcium or alkalinity!!
    Just checking to see how the pool is doing now?
  1. Sandpaper like stuff on bottom of pool
    By motomomof2 in forum Dealing with Algae & Slime
    Last Post: 05-29-2013, 05:51 PM
  2. fiberglass pool reoccuring yellow sides
    By lorididrickson in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 07-25-2012, 06:49 PM
  3. Pool liner feels like sandpaper
    By pleasehelp in forum Dealing with Alkalinity and Calcium
    Last Post: 06-03-2012, 09:26 PM
  4. Sandpaper rough feeling to bottom of pool??
    By pairadocs in forum In-Ground Pool Construction and Repair
    Last Post: 05-30-2007, 09:20 AM
