Thread: Filter keeps losing suction power
    Jun 2012
    Massachusetts
    Default Filter keeps losing suction power
    Greetings. I've had a 24' above ground pool with Starbright sand filter for five years. It was used when we bought it.
    I just hooked up the filter last week. It started running fine. But after several hours there was little or no flow through the system. It's not sucking in and not blowing out.
    When I backwash it, it goes back to normal. But a few hours later there's no flow again. The pump sounds fine. There doesn't appear to be any leaks in the filter system. The skimmer is not taking in debris. The water is clean when I backwash.
    Thanks.
    Default Re: Filter keeps losing suction power
    If your filter has a multiport valve on it, put it on "Recirculate", and see what happens. If the same pattern occurs, then the problem is most likely in your pump. If it does NOT occur on "Recirculate", then the problem is in your filter.
    Jun 2012
    Massachusetts
    Thanks Doc.
    I did not have the problem in Recirculate mode.
    Is it fixable or time for a new filter?
    Thanks.
    Quote Originally Posted by dimchandelier View Post
    Sorry, I don't know anything about "Starbright" filters, and without seeing a parts list I don't know.
    Jun 2012
    Massachusetts
    The o-ring where the valve body connects to the filter was broken. I replaced it. That helped some. It runs longer before losing power. Still not right though.
    Jun 2012
    Massachusetts
    I found a hairline crack in the multi-valve top. Put some JB Weld on it. Working fine now.
    Thanks.
    Your post may help someone else in the future who has a similar problem. Thanks for sharing your fix.
  1. DE pool filter losing pressure
    By herzog82 in forum Pool Equipment & Operations
    Last Post: 06-19-2013, 11:46 AM
  2. Losing water when filter is running
    By sztaylor in forum Pool Equipment & Operations
    Last Post: 10-04-2011, 10:07 PM
  3. filter basket losing water
    By Cold Drink in forum Pool Equipment & Operations
    Last Post: 05-29-2007, 01:19 PM
  4. Losing power when vacuuming
    By lange in forum Pool Equipment & Operations
    Last Post: 08-09-2006, 01:11 AM
  5. Filter losing suction
    By Atomic in forum Pool Equipment & Operations
    Last Post: 04-24-2006, 12:33 AM
