To shock or not to shock
Is shocking necessary on a weekly basis if things seem to be ok? Our pool is covered with a solar cover as the pool for the next week or two will not be used due to rain and cooler weather.
The water is pretty clear, and we have been running the robot and cleaning the sides every other day, and our heat pump is set at 75 and the pump is running 24/7. We also have trichlor tabs in the floater.
Testing shows with the Taylor 2006
CL 5
FC 3
PH 7.4
Hardness 100
TA 120
CYA 30-50
It has been a week since the last shock and I did so because we had pretty heavy use one day.
Thoughts and thanks in advance!
doughboy 24x24 AG round 16,100 gal with 3.5 and 6.5 deep end. Doughboy sand filter. Doughboy 1 hp pump. Tropi-cal 75k btu heat pump.
