Re: Hello from Montreal!
You know our opinion of test strips so I won't go into that here.
Your target shock level for 30 ppm CYA is 15 ppm FC constantly. Could be you have that, could be much higher, could be 10.5. Without a reliable way of testing higher chlorine concentrations you're just guessing, Nick. Then again, with the test strips you're guessing at the CYA as well so, in reality, we're just dosing the pool with a lot of hope.
Can you reach the bottom of the deep end with a leaf net on a telepole? Even if you can't see what you're doing you might be able to pick up some larger debris, leaves and sticks and such, if you think that's what's down there. Maybe nothing, given the winter cover.
My best suggestion is to keep adding bleach. And check into an online vendor who sells Taylor products in Canada.
