Results 1 to 10 of 43
Thread: White gritty scale
    Default Re: White gritty scale
    Finally getting around to pictures:
    Color enhanced image:
    How's the battle with the grit going?
    Jun 2012
    Ohio
    Well, I am glad to report having a bunch of rowdy kids swimming in the pool seemed effective to pull up some of this stuff-there literally were piles of this grit in the corners, and on the floor which i was able to vacuum up the next morning. They also didnt even notice it as they were swimming, of course, its always on my mind, but they could have cared less!
    There has been substantial amounts that have started to come up especially in the shallow end floor and the deep end floor.
    I still have several areas on the walls, and on the seams around the deep end that just want to keep holding on.
    I brush every night (i dont scrub), and every swipe does produce a cloud so I know its coming loose, just not as fast as I guess I want it to come off!
    My TA has been difficult to get below 120. TA has held now for the last four days betw 120-140.
    I have my returns turned up, and I use a power nozzle on my fill hose to spray over the surface of the pool water and create bubbles and fizz, but am thinking I may need to get a little more agressive on my aeration?? I saw where some have rigged up pvc pipes to do this-do you suggest that, or just stay the course with what I am doing?
    My PH as come up several times (last read this morning was 7.5), but I just add a half gal of muratic acid and it drops by the next morning to 6.8.
    Another question though, each season I use the Tri Chlor pucks in my chlorinator, but have not used any yet since opening the pool. Would you suggest that I go ahead and start putting the pucks in my chlorinator?
    All in all, I would say I am winning with your advice, just have a feeling this is going to be a long war!
    Thanks again PoolDoc
    16'x36' rectangle 21K gal IG vinyl pool; Trichlor feeder, & hand dispense; Fox pools sand filter; A O Smith, Century, 3/4 horse pump; hrs; HTH 6 way test kit, drops; well; PF:5.7
    The calcium carbonate bits are INCREASING both your TA and your CH, as they dissolve or break down. So it's not too surprising that you're finding your pool resists going below 120.
    As the sand algae bits diminish, you should be able to lower the TA, and clean up the remnants.
    Jun 2012
    Ohio
    Hi Pooldoc,
    my TA has finally dropped to 70-80ppm (this is the second day it has read that, was stuck at 120-130 for most of last week. I have been holding my PH between 7 and 6.8. it has generally taken 3/4 to one gallon of muratic acid, every other day to hold it there, the highest my ph has spiked was 7.2-7.5. my current chlorine is 1-2ppm.
    The most progess i see on the scale coming off is usually right after a heavy swim day (kids jumping in and splashing all day). literally in my shallow seams and corners there will be little piles of it which are easy to vacuum.
    I still brush every day, then vacuum the evening.
    the lighter patches are diminishing for sure, specifically in my shallow end , but the real dark, thicker areas in my deep end dont seem to be budging much (these deep end patches have remained their same color, the darker brown, while the stuff that comes off is much lighter).
    Just thought I would let you know an update. I havent used any pucks and will not!! I havent had to shock the pool, water has remained clear.
    If you have any suggestions, or if you think I need to change something in my routine, please let me know.
    I am a little concerned that the heavier stuff at the deep end does not seem to be 'chipping' off as quick.
    Thank you again for your help and advice,
    No suggestions -- it sounds like you are doing exactly what you need, and getting the results you were seeking.
    Just don't get impatient, and start scrubbing the liner, or lower the pH too far -- and I think it will be fine.
