Thread: Hydrostatic relief valve
    Jun 2012
    Ohio
    Default Re: Hydrostatic relief valve
    Got a side question to this. Since I have it out and I read somewhere these things should be replaced every few years, I thought I might take this opportunity while the pool isn't full of water. The old one was brass and looked very aged. Is there an advantage to buying a brass one versus a PVC? They seem to cost about five times as much so I thought I would check before making the purchase.
    25'x40' oval 33K gal IG concrete pool; hand fed liquid chlorine; Hayward S244T sand filter; Hawyard Super pump 1.5 HP pump; hrs; Taylor K-2006C; city; PF:3.6
    Jun 2011
    In the Sticks near Houston, TX
    Please don't paint your pool. You're going to spend at least $500-600 on materials and you'll have to have it re-done within two seasons unless you really know what you're doing and buy the correct stuff. If the plaster is in even halfway decent shape just leave the surface alone.
    I speak from experience. I spent $500-600 painting my pool and 2 days of labor and it was peeling by the end of the first seaon and we barely made it through season 2. I then had it professionally replastered for a cost of $2500 and the result has been much better.
    ~18K gal IG Gunite -- 1-HP Pentair Whisper Flo with new 2-speed motor. Intermatic T1000 Dual Speed Timer -- Tagelus 60D sand filter
    Hayward SWCG (up to 40K gal.) -- Polaris 280 and booster pump -- Rainbow (now Pentair) in-line chlorine Feeder.
    Jun 2012
    Ohio
    Too late, that was last weekends project. Since replastering only lasts 5-10 years cost would be a wash even if I only get 2-3 years out of it. The previous owners had already painted and it was chopping up in spots so we sanded it down and recoated. Considering the paint was in decent shape even after several years of neglect, I gotta imagine with proper care it should do as well. Back to my topic though, does anyone have any input on hydrostatic valve?
    Jun 2011
    My original plaster lasted 20 years. I hope this set lasts at least 15. I hope you have better luck than I did.
    I would get a new drain plug. I can see benefits to either PVC or brass. What does it screw into? If it screws into plastic I might choose PVC. Either way I don't think there is a wrong answer.
