Thread: 5k gallon pool -- my water is never clear
    Default Re: 5k gallon pool -- my water is never clear
    Start by filling out the Pool Chart (abt 30 seconds)
    Pool Chart Entry Form
    Pool Chart Results
    and by getting a test kit. Get a HTH 6-way drops kit if your local Walmart has one; if not get a cheap OTO (yellow drops) kit. Then, read the test kit info page (my signature) and order a K2006. When you get it, test BOTH your pool water, but even more importantly, your WELL water. Do not test the stabilizer level now - there are only a few tests in the kit for that, and you don't need them yet.
    Also, tell us if you want to use the pool now -- on a get-by basis -- or if you'd rather wait till you are in position to fix the problem.
