Results 1 to 10 of 10
Thread: dirty water
    Default Re: dirty water
    Love your street name!
    My favorite around here are "Hog Jowl Rd" (in the small town where I grew up) and "Booger Holler Rd" (on the way to a pool I serviced -- it's actually a Cherokee reference, rather than what people think). I hate the faux 'upper class' names builders create, like "Oake Pathe Lane" . . . . or "Willow Oak Drive" . . . in the middle of an old tree-less cow pasture!
    OK. Enough of that.
    Sounds like the dirt is blowing through your filter. AG pools are almost always installed with oversized pumps and undersized filters, when what they need are oversized filters and undersized pumps! With a sand filter, the dirt can be SHOVED through the sand. Also, during backwash the high flow tends to blow the sand out of the filter.
    So, do this:
    1. Open your filter, and check your sand. You may need to add some.
    2. If the filter is low, then you also need to slow the flow through the filter. You can do this by running on low speed (if you have a 2 speed) or by putting a valve between the pump and filter and throttling the flow, or by modifying or replacing the pump or by (best of all) getting a bigger filter.
    3. Complete the pool chart (about 30 seconds) it will make it much easier for us to give you good advice
    Pool Chart Entry Form
    Pool Chart Results
    Jun 2012
    Ohio
    k the pumps a 1.5 hp 1 speed cheaper for a new pump or filter and which one ya recomend when your talking filter your talking complete unit right thanks
    To offer you replacement ideas, short of a complete pump filter combo, I'd need pump and filter MODELS and sizes.
    Jun 2012
    Ohio
    filter is a heyward s210t1580 filtration area f.t-2.2 m-0.21 design flow rate gpm-44 lpm-167 pressure loss at design flow rate-psi-2 BAR- 0.14
    pump power flo l.x series 1.5 h.p it,s a heyward also
    Jun 2012
    Ohio
    still looking for help
    I've alerted Ben that you have supplied the requested information. Hopefully, he'll be able to take a look at this soon. We've been swamped ........
    I'm not clear on what you want, or what's happening.
    1. Your first post indicates your pool gets dirty when you turn the pump & filter on. Are you saying, "Dirt comes out of the pool returns, and clouds up the pool?" or are you saying something else?
    2. Did you check your pool filter's sand? Is it full? Is the sand level, inside the filter? If you haven't checked it, do so, and get a small handful of sand and put it in a sandwich bag.
    3. Did you try throttling flow through the filter, like I suggested? Do you understand what I meant?
    4. You report at having a Hayward s210t1580 -- that's a pump and filter combo. This is the manual that goes to that combo: manual49.pdf. Is that what you have?
    5. Are you willing to spend maybe $800 to get a better system? Or would you prefer to get your existing system to work better?
