k the pumps a 1.5 hp 1 speed cheaper for a new pump or filter and which one ya recomend when your talking filter your talking complete unit right thanks
To offer you replacement ideas, short of a complete pump filter combo, I'd need pump and filter MODELS and sizes.
filter is a heyward s210t1580 filtration area f.t-2.2 m-0.21 design flow rate gpm-44 lpm-167 pressure loss at design flow rate-psi-2 BAR- 0.14
pump power flo l.x series 1.5 h.p it,s a heyward also
still looking for help
I've alerted Ben that you have supplied the requested information. Hopefully, he'll be able to take a look at this soon. We've been swamped ........
I'm not clear on what you want, or what's happening.
1. Your first post indicates your pool gets dirty when you turn the pump & filter on. Are you saying, "Dirt comes out of the pool returns, and clouds up the pool?" or are you saying something else?
2. Did you check your pool filter's sand? Is it full? Is the sand level, inside the filter? If you haven't checked it, do so, and get a small handful of sand and put it in a sandwich bag.
3. Did you try throttling flow through the filter, like I suggested? Do you understand what I meant?
4. You report at having a Hayward s210t1580 -- that's a pump and filter combo. This is the manual that goes to that combo: manual49.pdf. Is that what you have?
5. Are you willing to spend maybe $800 to get a better system? Or would you prefer to get your existing system to work better?
PoolDoc / Ben
sand is full and yes seems like dirt is coming back out into pool would like to get current system working better not sure on the throttling you are referring to????
and yes that is the system we have thanks frustrated in ohio
