Results 1 to 10 of 76
Thread: fighting mustard algae
    Kateyru is offline Subscriber Thread Analyst Kateyru 0
    Apr 2012
    Alabama
    Default Re: fighting mustard algae
    My head is spinning...
    okay, I use K-2006 kit and no 5ml marker so I might could TRY to guess at 5ml...or use a measuring cup or spoon. I also have a basic OTO test kit, just fyi. My Walmart doesn't have that HTH test kit.
    will leave TA alone for now...would love to do the borate thing but want to make sure algae is really gone.
    CYA at 35 was my eyeball estimate. If I add Sam's dichlor, I'm sending FC back up, correct? Do I need to?
    I don't think pool leaks but we add water regularly/daily. I live in summer hell, oh, I mean Montgomery, Ala where it is very hot and very humid. I don't backwash often, pressure rarely moves much. Great thought about the gauge, how would I know if it works correctly?????
    Ben, I just saw email with pool hx in inbox and will get on that.
    Would one of you guys please move to Montgomery
    Thanks, thanks!
    16'x30' rectangle 22K gal IG vinyl pool; SWCG; Hayward Pro SEries S220T sand filter; Hayward pump; hrs; Taylor K-2006 ; city; PF:5.5
    Quote Originally Posted by Kateyru View Post
    Actually, borates would help with that.
    But . . .
    Sounds like a leak. You need to do a bucket test, to find out:
    http://www.poolforum.com/pf2/showthread.php?11252
    Apr 2012
    Alabama
    ok, will do test. Should pump be on overnight for the test?
    thx
    Apr 2012
    Alabama
    ok, I'll leave it on. I sure hope we don't have a leak...
    thanks
    me too.
    Apr 2012
    Alabama
    Not able to do bucket test last night so will do tonight.
    I have a glass jigger with 5 ml so measured pool water then put in K-2009 tube and tested for FC. Worked GREAT! FC = 10. I guess it might be more challenging if FC is low.
    Just sent husband to Leslie's with water sample to see what test results they get. Told him NOT TO BUY anything!!! I've used sooooo much reagent this summer shocking pool at regular level then mustard algae level multiple times. Glad to find a way to test with less reagent!!!!!
    Can I use OTO test when FC is back to 5?
    will check back about leak.
    Thanks!!!!!!
